It is currently Wed Aug 20, 2025 4:03 pm
 Post subject: fret files - worth it?
PostPosted: Thu Feb 20, 2014 8:50 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Right now I use triangular files for fret crowning, it's cheap and I only need one file for crowning every frets under the sun. However there are drawbacks. It takes a bit of skill to use and it's prone to slipping which often scratches the fingerboard or the fret top. It also takes a lot longer since you need to crown each side of the fret separately which means crowning takes twice as long. I'm wondering is the 3 in one fretfile worth it and does it save any time? I'm hoping to reduce the time it takes to crown frets because I'm getting a little more fretwork and if I can work more efficiently, I can meet any possible increase in demands.
Typhoon Guitars
PostPosted: Thu Feb 20, 2014 9:13 pm
Well.... which fret files are you referring to... specifically?
PostPosted: Thu Feb 20, 2014 9:16 pm
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
After 45 years and trying every kind of fret file, I still use only triangular files for crowning frets. . .
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post: Bjornstad (Mon Feb 24, 2014 6:59 am)
PostPosted: Thu Feb 20, 2014 9:17 pm
Last Name: Russell
State: Michigan USA
I did all my fretwork with a couple of triangle files and a small flat one. A few years ago I decided to get the 3 in 1 file, I like it because it is quicker but it has a tendency to chatter which leaves marks. it is also pretty aggressive so it is easy to over do it. I find lately that I use it for just rounding off the top flats and then I grab my triangle files. It does save time so if that is what you are after then it can't hurt to get one.
If you use your triangle file and find you slip off the frets then buy some of those little spring steel fingerboard guards, They are great to have and I use mine all the time now. I use to tape off the board but now I just use the guards. It keeps the fretboard clean and keeps from getting scratches if you do slip off.
Bob
Added Note:
If you do get a 3 in 1, the files will fit in the handle either way but only one way is correct. If you put them in backwards the file cuts on the pull stroke and it can slip out. (ask me how I know....)
PostPosted: Thu Feb 20, 2014 10:31 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Another thing is the frets over bodies on set neck guitars... I wish they have a gooseneck triangle file, but the 3 in 1 file has that feature. It seems those last 5 frets are the hardest to do.
Typhoon Guitars
PostPosted: Thu Feb 20, 2014 10:36 pm
First name: anthony
Last Name: wickman
City: tallahassee
State: florida
Zip/Postal Code: 32301
If you get the 3 in 1, get the diamond version. Works on the push or pull stroke, and no chatter.
PostPosted: Thu Feb 20, 2014 11:07 pm
I use a triangulkar file to rough them in and I finish up with the diamond crowning file.
Old growth, shmold growth!
PostPosted: Thu Feb 20, 2014 11:17 pm
It's expensive, but the stewmac diamond fret file is so completely worth it. Does both narrow and medium frets and will last so incredibly long. Done hundreds if not more on mine and still going strong.
I use it by itself to crown the fret, then tuck a pinch of 1000 grit in the groove, then 2000 grit and your fret is buffed, at about 30-45 seconds a fret. Then a flat block with 800 on it to level a small flat spot on top, easy to see cause it's duller. I wouldn't be without it, despite the seeming extra cost. Furthermore, I believe you can find cheaper knockoffs probably made in the same factory but not stamped for stew Mac...
These users thanked the author meddlingfool for the post: DannyV (Fri Feb 21, 2014 11:32 am)
PostPosted: Thu Feb 20, 2014 11:50 pm
City: chicagoland
State: illinois
i'm impressed so many of you use triangle files for part or all of the job. i can't even imagine it...
PostPosted: Fri Feb 21, 2014 12:14 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I got a diamond fret file one time and it gave a school bus profile... I assume they solved that problem?
Typhoon Guitars
PostPosted: Fri Feb 21, 2014 12:41 am
I started with the triangle file, and honestly I think I can do a better job with it. It just takes twice as long and it's easier to mess up. I love my offset diamond file , but it does give sort of that school bus effect. But once all is said and done I don't think you can really tell the difference. I have the diamond 3 in 1 also. If you are on a budget, its a good tool.
PostPosted: Fri Feb 21, 2014 1:50 am
That means the diamond file just knock the edges off the crown.
Honestly, for me, trying to round the entire top of the fret with just the diamond file is ridiculously time consuming. Plus, if the fret has spots that are flatter than others you'll get an inconsistent result.
The triangle file is great for rough shaping the top of the fret and is faster than the diamond file, and allows you to have more control over the process. Once the fret is evenly and consistently crowned, the right size diamond crowning file lets you have a nice round top with a paper thin untouched line across the center.
So yes, I think the files are worth it. I bought a set of the cheaper ones off Ebay, and the Stewmac ones beat them by a long mile.
PostPosted: Fri Feb 21, 2014 2:04 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Where do I get the diamond 3 in 1 file? I don't think Stewmac or LMI has it.
Typhoon Guitars
PostPosted: Fri Feb 21, 2014 4:04 am
I have the old 3 in 1 Gurian file. Pretty hard to find a tool that will actually do a worse job.
Like a few previously, I use a decent Grobet. But not a triangular file. It's a short 6" fine cut flat file. I find it easier to judge the angle with the flat file.
PostPosted: Fri Feb 21, 2014 9:44 am
First name: Craig
Last Name: Gordon
Zip/Postal Code: 14216
Frank, you told during a visit to Roberto-Venn that you preferred a cant file. Do hou have a particular size that you like, and where do you get yours? Do you put a safe edge on it?
PostPosted: Fri Feb 21, 2014 10:15 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I know Stewmac sells a set of triangular files for fret crowning, but since those files are so cheap at hardware stores, I never bothered with them...
Typhoon Guitars
PostPosted: Fri Feb 21, 2014 10:19 am
I prefer the diamond offset files.
PostPosted: Fri Feb 21, 2014 10:50 am
First name: Frank
Last Name: Ford
City: Palo Alto
I like to have various sizes of the same kinds of files. If I get chatter marks with a big file, I switch to a smaller one that has different tooth spacing, for example. And, different sizes fit different instruments and situations. That goes for triangular (equilateral or cantsaw) flat, or whatever.
Here's a quick bit on making safe edges: http://www.frets.com/HomeShopTech/Magne ... efile.html
I usually use my belt sander, but a regular carborundum stone works quite well with a bit of elbow grease.
Making your own tools:
1. Saves money
2. Gives you special stuff you can't buy
3. Makes your mind flexible to possibilities
4. Builds skill
5. Helps you learn and improve your use of tools
6. Keeps you young (at 70, that's just wishful thinking)
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post: Bjornstad (Mon Feb 24, 2014 7:00 am)
PostPosted: Fri Feb 21, 2014 2:06 pm
I should probably get a vise that doesn't have polyethylene cauls.
PostPosted: Fri Feb 21, 2014 2:30 pm
First name: Mark
Last Name: Chinworth
City: Kirkwood
Zip/Postal Code: 63122
For fret crowning you can make a simple tool that's fool proof:
Cut a fret kerf into a piece of scrap wood.
Hammer a fret into the kerf.
Double-stick tape a narrow strip of 220 sandpaper (or use self adhesive sandpaper) onto the fret.
Grab a small chunk of scrap ebony, with one of the face dimensions close to 1/4" x 1.5". Sand or plane that face smooth, with a slight convex profile on the long dimension.
Align the center-line of the long dimension with the fret, and slide the ebony along the length of the fret thus sanding the fret shape into the ebony.
Double-stick tape a narrow strip of 220 or 320 sandpaper (or use self adhesive sandpaper) into the resulting channel.
After the frets are leveled, slide the channel (with sandpaper) along the length of the fret thus transferring the rounded profile of the channel onto the fret.
I usually replace the sandpaper once or twice during one fret board re-crown job, YMMV.
These users thanked the author Mark Chinworth for the post: dzsmith (Fri Feb 21, 2014 8:37 pm)
PostPosted: Fri Feb 21, 2014 6:38 pm
I think it's actually a 2 in 1 with 150 & 300 grit.
PostPosted: Fri Feb 21, 2014 7:29 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
it is 2/1 I bought 2 1 for thin frets and the other for med frets . abt 130$ with shipping for the 2 from stew-mac
PostPosted: Fri Feb 21, 2014 9:34 pm
Exactly. I have one and find it very handy for touching up frets under strings, occasionally, after using the Rick Turner method of correcting high frets with Aluminum angles with sandpaper.
PostPosted: Fri Feb 21, 2014 9:39 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I had one of those dual grit ones before. The medium one had such a wide profile that I actually ended up grinding the top of the fret rather than the side.
Typhoon Guitars
PostPosted: Fri Feb 21, 2014 9:57 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I have the offset 300 grit one from Stew Mac. It does wide and medium frets. I think it is great, and it cuts so quickly, I don't see any need for the 150 grit one,
Users browsing this forum: Bing [Bot] and 10 guests
